oil leaking around distributor
Does anyone else have oil leaking around their distributor area. Anyone know a way to fix this and if so where can i get the part from other than honda?
RE: oil leaking around distributor
There is an o ring seal near the shaft of the distributor that needs to be replaced. Regular parts places may have them, but it may save you time by just getting it from honda.
is it that hard to replace? anything i need to be careful of?
Fixed the oil leak around the distributor but now its leaking again. So I replaced it with a new ring for the distributor but now its leaking again. does anyone have any idea to what I should do about this leak?
sacicons will know, where are you at sac?
make SURE the gasket around the valvecover is placed correctly. a lot of times people put that thing in wrong and you cant even tell.
