Oil pressure sensor
Is it located right above the oil filter? How do you remove it? I didn't see any where to wrench it at.
RE: Oil pressure sensor
Yes, it's located directly above the fuel filter and has a wire attached to it.
If I may ask, what are you trying to remove it? |
is that the wire you would use to wire in a oil pressure gauge?
please don't thread jack. Research oil pressure gauges, there are different kinds and different methods of hooking them up.
i'm trying to connect an oil feed lin to my turbo.
dont use that
ORIGINAL: hondapwr dont use that |
| All times are GMT -8. The time now is 04:55 AM. |
