oil pressure sensor fitting
Does anyone know what size the oil pressure sensor fitting is on a 1995 Civic DX? Is it the standard 1/8 NPT fitting? Thanks,
Andy |
i believe so.
The instructions in the Haynes Manual say to use a little bit of thread seal to keep the oil in, makes sense. Do you need to be thinking about what you use being safe for the O2 sensor, though, the way you would when using a gasket sealer while replacing a valve cover? Thanks again,
Andy |
just use Teflon tape and yes it is 1/8
| All times are GMT -8. The time now is 01:15 AM. |
