Oil In Spark Plug Wells
When I did a tune-up today I noticed that my #3 plug had oil on the threads - I have been noticing a burnt oil smell over the past month, but assumed it was because I used 'generic' oil - The good news is that there is no water in the oil when I drained it, and there is no loss of power or gas mileage, so I am 99.9% sure it's not a blown head gasket - I am planning on replacing all the valve cover/well gaskets tomorrow, along with my PCV valve - My question is, if it turns out that the new gaskets and PCV valve do not solve the problem, what else could it be?
Anyone? :-/
oil in spark plug wells
could be the o-rings under the rocker arm assembly. other than that, not sure.
Spark plug tube seals.... most likely culprit especially if it's an accord.
Yea we had an accord and oil kept getting on the #3 plug and made the plug wire shoot off while driving. Replaced the tube seals (very easy) problem solved.
Mine is a Civic (D16Y7) - I don't have an issue with the plug wires popping off, but when I changed my plugs I noticed the oil on the threads, and the tips of the plugs were toasted - Once in a while I get a brief whiff of burnt oil, but no performance issues - I have noticed the past few months I have been losing oil, but couldn't locate any leaks, so this has to be the reason why - Now I just need one good day out to change everything over (No garage to work in o.O)
The plug tube seals are about the only possible reason to have oil on the outside of the spark plug. No other way to get it there unless you spilled oil when filling.
Originally Posted by TiggerDX
(Post 790824)
