HondaCivicForum.com
-   -   Old School Timing Light: OK to Use? (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/old-school-timing-light-ok-use-93998/)
Islander Aug 22, 2012 11:33 AM
I have an older timing light that intercepts between the plug wire and dist cap, as opposed to newer ones that clamp over the wire.
Is there any issue using this to set ignition timing on my '93 Del Sol?
Not sure if changing the impedance of the plug wire would mess with my brand new coil? It still completes the circuit to the plug, just has an additional low-resistance metal piece in there.
Thanks!
mk378 Aug 22, 2012 12:40 PM
Those will work. Be sure it is securely connected, don't let the engine run with a spark wire disconnected.
Islander Aug 22, 2012 12:47 PM
Thanks MK...will give it a try. And thanks for all the distributor advice!
boiler1 Aug 23, 2012 07:45 AM
I blew my ignitor using my dads old craftsman interceptor type fyi.
