Opinion on cost to fix.
Old Jul 5, 2009 | 05:40 PM
sp44's Avatar
Default Opinion on cost to fix.
Got a quote from import mechanic.
Head gasket, 600.
Oil pan gasket, 250
Sway bar link bushings, 200.
93 EX
Old Jul 5, 2009 | 06:07 PM
ej6buddy's Avatar
Seems a little high to me. I don't know if you're mechanically inclined or even have the workspace or tools, but the sway bar links and oil pan gasket isn't too hard of a diy. The head gasket is a little trickier if you've never worked on an engine before.
Old Jul 5, 2009 | 08:25 PM
Lewy2k's Avatar
You could easily find someone you know that is knowledgable about cars to help you replace a head gasket. $600 is a little steep
Old Jul 5, 2009 | 10:07 PM
jpnolan's Avatar
$600 isn't terrible for the head gasket. If you don't know cars fork over the money or if youre in the bay area I'll do it for $300.
Old Jul 6, 2009 | 04:31 AM
sp44's Avatar
What's the possibility of the head needed to be machined if I do it myself?
Old Jul 6, 2009 | 01:53 PM
ej6buddy's Avatar
Was it overheated to any degree? And it's a must to check the head and deck.
Old Jul 17, 2009 | 12:35 PM
zsatbecker's Avatar
if you live in minnesota ill do it for 250 hahaha
Old Jul 25, 2009 | 10:13 AM
sp44's Avatar
Does this look right? I've got a little leak on the driveway. Doesn't look tight to me!
Old Jul 25, 2009 | 10:14 AM
sp44's Avatar
Might help to post pics.
Attached Thumbnails Opinion on cost to fix.-img_0905.jpg   Opinion on cost to fix.-img_0907.jpg
Old Jul 25, 2009 | 10:23 AM
is that oil? or water?
that might be a main seal from crank.
have you done a compression test?
does it overheat?
does it have water in the oil?
does it have alot of white smoke coming out the exhaust?
