HondaCivicForum.com
-   -   Overfill Oil in 2001 Civic (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/overfill-oil-2001-civic-35625/)
civic2001 Jan 7, 2007 01:35 PM
I just noticed that the crew who did my last oil changes put about a liter too much oil in my 1700CC 2001 Civic LX. That was about 3000 kM ago, any ideas as to the potential harm already done?
ashcheerit2000 Jan 7, 2007 05:02 PM
RE: Overfill Oil in 2001 Civic
i dont think it'd do much harm just make your motor run slugy
cpl rampage Jan 7, 2007 06:38 PM
you could run into problems with air bubbles being created, you best bet would be to drain the oil, or at least part of it, and then re-add untill it is within spec
20civic00 Jan 7, 2007 09:23 PM
I heard it takes a toll on seals. It allows the engine to have to much crank case pressure? Just what I heard. Good luck, Jason.
drbyers Jan 7, 2007 09:26 PM
it's true. you can blow out the seals if there's too much oil.
Forty04 Jan 8, 2007 11:24 AM
ORIGINAL: 20civic00
Exactly. Just let some of it drain out, then refil to spec as mentioned
b8teen Jan 9, 2007 12:07 AM
if you didnt blow smoke, then your seals should be ok.
civic2001 Jan 9, 2007 10:07 AM
It appears the oil change crew threw in 4 liters where they should have only put in 3.2 Liters. Then I drove from Calgary to Yuma,AZ at 75 MPH speeds. Had the oil changed yesterday in Yuma (with 3US Quarts)which put the dip stick level 2/3 theheightbetween two markers. No signof damage/trouble yet.
