P0141 on 96 Civic LX
Old Jan 10, 2013 | 02:56 PM
dc5_dy's Avatar
Exclamation P0141 on 96 Civic LX
i got a code of P0141 "O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)" couple of days ago and erased the code then today it came back. i did some research on this code that it might be the #15 fuse (7.5) or it could the the connection on the engine bay (from the sensor) "The engine wire harness is rubbing on the intake
manifold bracket."
http://www.tegger.com/hondafaq/tsb/civic/x99-029e.pdf
if these 2 are ok.. i just have to replace the 02 sensor (secondary)?
btw, is front, primary? and rear is secondary?
Honda Part #'s
36531-P2E-A01 = FRONT (#8)
36532-P2E-A01 = REAR (#9)
Replacement Parts:
NGK/NTK
NTK24542 = UPSTREAM
NTK24633 = DOWNSTREAM
DENSO
234-4099 = UPSTREAM
234-4065 = DOWNSTREAM
ok, i checked fuse #15 (7.5) and its not blown. i didnt check the wiring on the engine bay because my fuse is ok. yesterday CEL came back again (3rd time) coz i keep on erasing it. so i was thinking maybe its really the sensor.. but which one?
Old Jan 10, 2013 | 04:03 PM
Part 9 is sensor 2, it is after the catalytic converter. In cars such as the EX with the more common design with the converter mounted horizontally in a pipe underneath the car, the sensor after the converter is closer to the rear of the car.
Engine cold, unplug the sensor (you will need to unclip the plug from the metal bracket first, it has a locking feature) and measure resistance of the sensor heater. The sensor heater is the two wires on the sensor that are the same color. It should be 10 to 40 ohms. Bad sensors are almost always open circuit.
Old Jan 11, 2013 | 08:01 AM
dc5_dy's Avatar
ok.. the lower part.. how do i check the resistance? im a noob when it comes to that.. do you have any pic? open circuit?
Old Jul 25, 2013 | 11:22 PM
dc5_dy's Avatar
i forgot to update this...
i replaced the secondary sensor and CEL was gone..
graymonkey44
Aug 8, 2010 11:00 PM
maco_26
Aug 20, 2009 08:20 AM
sixwhip14
Jan 27, 2008 02:19 PM
viper200392630
Oct 10, 2005 09:56 PM
