panel removal
So I'm wanting to install a new head unit in my 01 LX but I'm having trouble with the clips. I found a PDF that helps me locate them:
http://www.tss-radio.com/images/HO-52-01.pdf but I'm not exactly sure how to disengage them. I have a small hook shaped tool but I'm not sure what to do. If anyone who has removed the control/cigarette lighter panel on the same gen civic can describe them, or better yet, provide a picture, I would be very grateful. Thanks... ~Stephen |
RE: panel removal
ttt
come on, surely someone has removed this panel before... |
RE: panel removal
ttt
RE: panel removal
ttt
i'll give it another shot... any help at all would be appreciated... |
RE: panel removal
What does ttt mean?
http://www.ledautomotive.com/HowToGu...shLEDHowTo.asp This is the DIY to convert your climate control to blue leds but it mainly tells you how to take off your cluster! Good luck |
RE: panel removal
ttt=to the top
RE: panel removal
thanks that is close enough to what i'm looking for! much appreciated!
RE: panel removal
So I finally got around to installing my radio and I thought I'd explain a bit...
First I removed the cigarette outlet panel thing. What I did was take a couple credit cards to slip behind the top corners which allowed me to get a grip and pull it out. (I suppose the proper thing to do is to use a tool to unclip the retainers, but this worked for me without damaging anything.) Next I removed a couple screws underneath the radio. They were kind of hard to reach. Used an 8mm wrench to do the job - they stripped very quickly with a phillips screwdriver. Then I used a credit card to slip behind one of the corners of the radio panel so I could grip it. There are 9(?) retaining clips holding this one on. I went around in a circle and gently pulled until each was lose, and it came right out after that. Hope that helps others understand the process. I found lots of misleading info out there. ~Stephen |
| All times are GMT -8. The time now is 06:17 AM. |
