PCV Valve
Old May 10, 2005 | 12:36 PM
chones2083's Avatar
Default PCV Valve
where is that thing? i drive a 97 Civic Ex. Is it underneath near the car - if that is where its at, i am sure its a pain to get to....
Old May 10, 2005 | 12:46 PM
AgentofDarkness's Avatar
Default RE: PCV Valve
PCV should be on the top of the engine by the Valve cover. Check around the intake many and look for the vacuum hose that connects the PCV valve to the intake/fresh air intake.
Old May 10, 2005 | 02:02 PM
97CivicEX's Avatar
If you follow the hose that goes down through the intake manifold you will find it under that(underneath the intake). It is probably easier to see through the bottom. Right above the oil filter.
Old May 10, 2005 | 03:04 PM
AOL.COM's Avatar
just put an engine in my 97 & happened to stumble across it --not easy to get to --under the intake manifold theres a black breather box behind a big *** wire harness --i did my when the enine was out --it a tight sqeeze[sm=signs003.gif]
Old May 10, 2005 | 03:26 PM
neon3kgt's Avatar
i pulled mine out by lifting the vehicle and removeing the oil filter. then i was able to pop it out.
dazzdillinger
Sep 17, 2007 03:35 AM
j_civic_ex
Apr 11, 2006 05:37 PM
johhny b
Apr 7, 2006 04:20 PM
98civiclx
Sep 14, 2005 12:56 PM
nees1212
Aug 5, 2005 10:58 AM
