Ping in the wheel
Old Oct 1, 2008 | 05:55 AM
Motor35's Avatar
Default Ping in the wheel
Yo!
Ya know how gravel sometimes gets in your wheelwell and pings around until it comes out? Well, I am having a regular occurance of that sound in my front wheels. It only happens between 40 and 50 mph and the feel of my ride hasn't changed. Everything feels fine, but that pinging noise is annoying!
Any ideas what it might be?
Thank you!
Hugs!
Kricket
Old Oct 1, 2008 | 05:59 AM
If it's more of a metallic squeaking, the brake pad wear indicators may be sounding to alert you of the need to replace them.
Old Oct 1, 2008 | 06:05 AM
Motor35's Avatar
Thaks Ron for reading, but I just had those redone. It isn't a squeal, nor a grind, more of a 'ping' that I occasionally hear in the driver's side wheel well.
Old Oct 1, 2008 | 06:15 AM
Put the front end on stands, remove both front wheels, and inspect the driver's side wheel hub, suspension components, and well for something loose or a foreign object. Inspect the passenger side for comparison.
Old Oct 1, 2008 | 06:30 AM
Motor35's Avatar
Could my springs be making a noise?
Old Oct 1, 2008 | 06:35 AM
That's a possibility that would be revealed during the inspection if you find that the strut is loose.
Old Oct 1, 2008 | 06:36 AM
Motor35's Avatar
Thanks cupcake
Old Oct 2, 2008 | 07:10 AM
e_rock's Avatar
It could be the expansion and contraction of the heat shield. My mom has a '99 LX and I've never heard a car pop and ping so much. That's kind of unlikely that it would become an annoyance, though.
What kind of pinging is it? Is it a hollow metalic ping or more of a knock or pop? First thing that came do my mind was have the inner and outer CV joints inspected! If the boots are damaged, they joint will need to be inspected and possibly replaced.
Old Oct 2, 2008 | 07:23 AM
Yeah, it's also worth considering the exhaust heat shields, which are a common source for metallic noise.
cfrank9689
Dec 3, 2010 04:26 PM
corey
Oct 20, 2008 09:23 AM
civicpimpinsc
Nov 3, 2007 04:27 AM
Civi23
Mar 7, 2007 04:32 AM
dooka4u4
Jun 6, 2005 08:48 PM
