PLEASE help me!!!!!!
Old May 30, 2012 | 08:54 PM
MisterBrusso361's Avatar
Exclamation PLEASE help me!!!!!!
so i have 1992 4dr civic with a d15b which is non v-tech. i took off the intake manifold to clean the butterfly and were it sits. since i had it off i also took apart the FITV (Fast Idle Thermo Valve) and then put it back together carefully counting the turns to were i marked its position to make sure its back in the right place....BUT NOW FOR MY PROBLEM...now that everythings back together when i start the car the idle pulses...going from 1 to 3 back and forth...
ive taking everything back apart several times adjusting the FITV half turn this way and that and full turns so on and so on til i just put it back to the original spot. maybe its the lack of sleep or the kids driving me crazy but im almost to the point of want to just get a new ride...please save me and save my civic
Old May 31, 2012 | 04:16 AM
FITV should be fully closed above 60 F. You can check by seeing if the port in the bottom of the throttle body before the throttle plate is sucking air. Excess air entering the intake from any source will cause idle speed to increase.
DontHateOnEG8
20
Sep 6, 2008 06:49 AM
dhdicato
Apr 14, 2008 07:25 PM
D16racerchick
Jan 3, 2008 05:15 PM
redridinhood
Oct 9, 2006 07:27 PM
Honda99Civic
Apr 20, 2006 10:13 PM
