plug and play my @$$
Old Apr 26, 2007 | 12:15 PM
batz_civic's Avatar
Default plug and play my @$$
ok i got my buddy's eg si cluster...and i want to put it in my 95 dx. so i gets to removing mine and wat do i see..only 3 plugs and the si needs four.not quite plug and play ..now does that mean the 4th plug in the back of the si cluster is uselessor do i have to go buy a clip and do some wiring?
Old Apr 26, 2007 | 12:20 PM
danomatic93's Avatar
June 2010 ROTM
Default RE: plug and play my @$$
Plug it in a see if there is a problem.
Old Apr 26, 2007 | 12:28 PM
ej6buddy's Avatar
the si cluster probably has slot for cruise control which is green i believe, since you have a dx which doesn't have cruise control,yours doesn't have a harness for cruise control (at least this applies to 6th gens, not too sure on 5th gens though)
Old Apr 26, 2007 | 12:30 PM
batz_civic's Avatar
ej6buddy thanx the plug is green so it is worthless.. great help. thank you
Old Apr 26, 2007 | 12:32 PM
Fiirkan's Avatar
ORIGINAL: ej6buddy
the si cluster probably has slot for cruise control which is green i believe, since you have a dx which doesn't have cruise control, yours doesn't have a harness for cruise control (at least this applies to 6th gens, not too sure on 5th gens though)
Exactly, i got an Ex cluster and it works fine. it had an extra plug too, but i had nothing to plug into it, and it worked fine
Old Apr 26, 2007 | 12:35 PM
June 2010 ROTM
I never thought of that. I have an EX so I have cruise control and the green plug. Sweet.
Old Apr 26, 2007 | 12:57 PM
windcalmer's Avatar
Nice to know. I was wondering what the green plug on mine was for.
Old Apr 27, 2007 | 03:15 PM
Firehawk989's Avatar
When you plug in an EX cluster to a DX, does the tach work, or do you have to do wiring for the tach?
Old Apr 27, 2007 | 03:25 PM
June 2010 ROTM
plug and play, yes tach works.
Old Apr 27, 2007 | 03:26 PM
ej6buddy's Avatar
ORIGINAL: Firehawk989
The tachometer pickup is wiring into ALL honda civic models, if you get a cluster with tach, and hook it up, then it will work, it's as simple as that.
