Plugs and Wires
I have a 96 civic dx with the 1.6L Non Vtec what would be the best wire, plug, and coil pack setup???
Use stock parts. A lot of fancy looking aftermarket wires are junk. Before 2001, all Civics have distributor ignition not coil packs. The cap and rotor are wear items and should be replaced as a tune up. The coil (inside the distributor) does not need periodic replacement, replace only if bad.
well i just did new wires and plugs and used NGK plugs and wires and with my discount it came to $140 canadian and i havent noticed any difference so i honestly think cheap is the way to go but it depends on how much you wanna spend
It don't matter how much I spend I was just gonna do a tune up so I need a cap and rotar then???
well it depends on how it looks but i would do it any ways this ways its all new
So just get all stock parts or is there a type that u found that worked a little better than stock
Originally Posted by 1.6LNVTEC
(Post 745228)
