HondaCivicForum.com
-   -   power locks not working (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/power-locks-not-working-81241/)
drumming24_7 Feb 28, 2010 10:30 AM
I have a 2005 4 door....recently my power locks have stopped working with the unlock button from the inside and the alarm control.....as of right now only one lock works (left back door)....the other three doors dont work.....any ideas on what i can do to fix this?.....
MistaGlock Mar 27, 2010 09:31 PM
do you hear any noise whatsoever when you press the door locks that dont work?? maybe you couldve blown out the control unit for the power locks?. did you modify them or work on the car at all prior to this happening? id suggest a blown fuse but i dont think thats the problem because you said one works...unless each door has its own fuse?? check under the dash for blown fuses
