Power Steering Fluid Leak
LOL
OP - whatever you do, while its still leaking be sure to keep it topped off. If you run it dry, you'll kill the power steering pump. And that ain't cheap, nor is it fun to change.
I raised the car and inspected underneath. There is a boot/belows that has a little nipple and a hose connected to the nipple. It seems that around where the nipple goes into the boot it is leaking. Is there supposed to be fluid in the boot/belows. -Kevin
No, the boot should be dry inside, it is just to keep dust out. Fluid coming out there means that the seal in the rack is bad, which is the most common place to leak. It is highly recommended to replace the whole rack rather than try to repair it. Also note that many generic fluids are not suitable for Honda and will ruin the seals. Be sure to use Honda fluid or one that is specifically labeled as suitable for Hondas.
ahhhh shiiiii, I just got my car back after having a problem with my Hondata. I drive out of shop and call them asking if they took out power steering, they said no of course and I puled over seing I needed fluid. No biggie... riiiiight. 2 Days later my steering gets harder. I check and fluid is damn near empty again! My driver boot is they only one leaking. Do I have to change out my whole rack if only one side is leaking? Im selling this car... I put way to much money into it and everytime I get one thing fixed something else needs fixing. I put a crate b18C thinking f it, just start out fresh... now this.
