power window help
does anyone know if there is a manual way to raise a power window...cuz mine jus died in the down postion, i replaced the master control switch cuz the button would not move but the window stil doesnt respond....wat could it be plz help b4 it rains
RE: power window help
do all the other ones work ?
maybe it just jumped the track which is a very common honda problem. The best thing to do is remove the door panel and look to see if it is still in the track then check to make sure the motor connection didn't come lose. You should be able to manually raise the window with the door panel removed.
first off do the easy thing,, chk to make sure the fuse is ok,, if it is,, you need to remove the door panel and test if the wires going to motor have power ..on the up position 1 has power the other ground, on the down position they are reversed ......if you got power and ground ,you got a bad motor ..
if you just want to raise the window, disconnect the 2 - 10mm bolts that attach the window glass to regulator, raise the window up all the way .. you might want to put some duct tape to keep and hold the window up ............it is a temprary fix .. |
