HondaCivicForum.com
-   -   Power window not working 2004 Civic LX (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/power-window-not-working-2004-civic-lx-97168/)
cobr888 Nov 13, 2014 12:14 PM
Hi all-
Neither the driver's master switch nor the door switch on the left (driver's) rear door will operate the window. I find that if I put the door switch in the up position then the dome light will dim slightly. It does not do it in the down position nor does it happen when I operate the master switch in either direction. I replaced the fuse so that is not it. What is likely to be my problem?
thanks!
