Problems starting on low tank
Car starts great almost all the time, but when I'm down to maybe a gallon in the tank, the car is really hard to start (takes a few tries)..
I mean sure, I can just fill up sooner and avoid the problem, but could this be fuel pump related?
Thoughts?
Thoughts?
Depending on how old your car is, you might have some crud in the bottom of your tank that clogs stuff up. A friend of mine ran his Honda on a nearly empty tank once and wound up clogging his injectors. Get some fuel cleaning additive and run it through a couple tanks of gas and see what happens.
Hmm, couldn't hurt.. Guess I'll try an additive..
Although I seriously doublt that there's much crud in the fuel tank.. That's for really old cars.. I once though I had to clean out my intake manifold, but when I opened it up it looked brand new on a 100K car.. And the fuel tank is one of the cleanest 'places' in the car.
By the way, Civic has a 12 gallon fuel tank right? I get the problem when there's 10.5 used up or more.. Hence, 1.5 gallons and below the car starts poorly (but runs fine)..
ORIGINAL: civic_ex_98
I am starting to see a pattern here... cause mine does it too, my theory is that when you leave gas sitting for a long period it starts to go stale, and then it is less combustable, but when you fill your tank that is fresh fuel. but the fuel at the bottom gets older and not used as much if it isn't mixxing well with the new stuff. so when the tank gets low that is what starts to get used. and the engine has to try harder to start.... like i said it is only a theory
