mk378 |
01-25-2012 06:51 AM |
I've done a couple by lifting the engine out the top with a comealong attached to the ceiling joists. Raise the front of the car and put on jack stands and take both front wheels off. Then undo the lower ball joints and swing the knuckles out so you can disengage the CV axles from the transmission. Also disconnect the exhaust (at the front of the converter), undo the shift linkage, unbolt the A/C compressor (Do not disconnect the refrigerant hoses), and remove the alternator while you are under there. Then put the ball joints back and put the wheels back on.
There is an extra spot for the prop rod to raise the hood really high so you can take the engine out (with transmission attached) without removing the hood. After you lift the engine out the top, roll the car backwards, set down the bad engine and hook up the new engine, push the car underneath the good engine and install it.
