question
ok, i need to change my clutch fluid. (manual trans) what is going to be the fastes/easiest way? is there a drain plug on the manual trans or am i going to have to disconnect a line on the resivor? im pretty sure there is a drain plug, but i thought i would ask because i dont feel like laying in the stupid snow to check, when it starts to get warmer, im going to change it in my (heated) garage.lol
RE: question
RTFM sir.... heh, I been wanting to say that forever. anyway, download the manual you should be good to go. http://hondatech.info/downloads/Auto/Manuals/
RE: question
hmm...i have a manual....thank you for that douche bag answer. i was really looking for "yes there is a drain plug" or "no, disconect the line from the resivor" i know i should have used the search right?;)
RE: question
ORIGINAL: the_turtle hmm...i have a manual....thank you for that douche bag answer. i was really looking for "yes there is a drain plug" or "no, disconect the line from the resivor" i know i should have used the search right?;) ...just kidding. Yes, jack the car up, take the passenger side wheel off (not neccesary, but helps a lot), and look directly at the side of the tranny. You'll see a cirle (about 1.5-2 inches in diameter) with a square in the middle. Put a socket wrench (without a socket) into that square, and turn it. Use lots of pb blaster, maybe some heat, whatever. I'm in a position right now we're I've got a chunk of socket wrench adaptor stuck in mine, because I pulled too hard with a breaker bar [:@] So yeah, be careful and it should go nice and smooth |
RE: question
ORIGINAL: the_turtle hmm...i have a manual....thank you for that douche bag answer. i was really looking for "yes there is a drain plug" or "no, disconect the line from the resivor" i know i should have used the search right?;) |
