2001 civic EX NO SPARK
Old 10-20-2011, 05:25 PM
techsol's Avatar
Default 2001 civic EX NO SPARK
Pulled a plug and get one spark on any of the spark ignitors and then nothing, engine just turns over.
Was starting a week ago has just sat in the driveway
Any thoughts? Crank sensor cam sensor other?
Spark plugs are good and full charged battery. none of the ignition fuses are blown, under the hood or the dash!
Any thoughts or how to check crank sensor
Old 10-20-2011, 06:00 PM
The CEL should cycle on then back off when you turn the key on but don't crank. If it does that, that shows the ECU is at least somewhat working-- hook up an OBDII scanner and check for codes.
Old 10-21-2011, 03:07 AM
techsol's Avatar
sorry for the ignorance, CEL?
There are no codes recorded on the scan.
What else short of a bad ECU would stop spark firing?
Thanks!
Old 10-21-2011, 03:33 AM
Check Engine Light.
Could be several things. You should measure that the coils, fuel injectors, and sensors are getting power while cranking. Also check the ground wires on the thermostat.
Old 10-21-2011, 06:14 AM
techsol's Avatar
Are there any "normal" culprits" with a No Spark situation ? Is started two days before?
Thanks Folks!
Ryans2kidz
02-12-2013 07:35 AM
pimp1913
08-26-2008 02:08 PM
stephelton
01-05-2007 11:10 PM
Kenneth Ames
11-07-2006 09:50 PM
Quick Reply: 2001 civic EX NO SPARK
