HondaCivicForum.com
-   -   Reading OBDII codes with paperclip, need help, Civic 98 (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/reading-obdii-codes-paperclip-need-help-civic-98-a-97676/)
Cyborg Ninja Jun 21, 2015 11:05 AM
1 Attachment(s)
I hope that I'll be able to get some quick help here. I'm trying to read error codes with a paperclip in my '98 Civic Ex. I was able to get a panel covering the ECU off. I think I figured out which plug I need, but it looks really hard to get to. There's a big ribbon or cable in the way, which isn't easily moveable because it's connected oddly enough to the ECU itself with a plastic band and some kind of screw it seems. And the plug itself, I don't know how to remove. It's absolutely tiny and I don't see an easy way to pull it out without tugging the wires. What do I do?
I believe it's the blue plug in a larger green plug near the top of the image. It has a brown and black wire.
Attachment 41508
cvcrcr99 Jun 22, 2015 09:46 AM
unbolt the ECU. work smart it should only be a 10mm bolt and a 10mm nut IIRC
