Refill Transmission Oil via dipstick tube?
Old Mar 3, 2010 | 12:19 PM
homers's Avatar
Question Refill Transmission Oil via dipstick tube?
Going to change my transmission oil this weekend. 2000 Civic DX, auto.
I have no question about draining and using the correct Honda Oil. My question is about refilling. Can I just pour the oil into the tube I use to check the transmission fluid level instead of removing the fill plug?
Old Mar 3, 2010 | 12:20 PM
norbster86's Avatar
Use the fill plug. It's pretty much impossible to over-fill your transmission that way.
Old Mar 3, 2010 | 12:32 PM
Old Mar 3, 2010 | 12:36 PM
homers's Avatar
thanks for the response. I just figured I'd replace the same amount of fluid via the dipstick tube as I drained. Searching for help and information it seems a little hard to reach the filler plug or you have to buy a hose and get it to the filler hole. I just thought it would be easier to replace via the dipstick tube.
Any other info or help is appreciated.
Old Mar 3, 2010 | 12:39 PM
As you can see in the diagram, refilling fluid through the dipstick tube is the correct way.
Kyle700
Oct 7, 2014 09:33 PM
conceptualpolymer
Aug 14, 2011 06:41 AM
cruiser56
May 2, 2010 12:37 PM
oilltd
Jun 10, 2008 04:06 PM
windcalmer
Mar 9, 2007 02:01 PM
