Removing radio/HVAC cluster, '98 Civic
Hi all,
I need to remove the black radio/HVAC control facia and cluster from a '98 Civic EX to replace some burned out dash bulbs. I don't see any obvious screws holding this thing in, and I don't want to force it.
Can someone please tell me the correct way to remove it without breaking anything?
Thank you!
Thank you!
get a TINY screw driver. and pop out the hazard and defroster button areas up top. not the button the bezel around the button there is a screw hiding behind each button.
also 2 or 3 screws from the bottom but you have to remove both sides lower dash trim panels to remove the center cig lighter trim panel. also remove the heater/temp slide cable from off the slide conection in the rear...
heres a few pictures... but i dont have the top buttons removed because i didnt know about them since my console was missing the top 2 screws from previous owner not putting them back!
but i found out about the 2 screws while removing a good console from the junk yard. hope it helps.....
http://s40.photobucket.com/albums/e2...sol%20removal/
i upgraded mine to 99-00 style.
but i found out about the 2 screws while removing a good console from the junk yard. hope it helps.....http://s40.photobucket.com/albums/e2...sol%20removal/
ya those top 2 screws i didnt think of either until i was at the junk yard with everything removed and the darn console was still very firm at the top. after screwing around for about an hour i tried poping one of the buttons out and found the top 2 screws! it doesnt look like those buttons pop out but they do!
addiction2bass
Interior DIYs
Aug 9, 2008 10:28 PM
bensminger2003
Mar 6, 2006 10:28 AM
