Replace lower ball joint
Old Mar 22, 2008 | 01:00 PM
gred001's Avatar
Default Replace lower ball joint
How many have you replaced the lower ball joint on your Civic. I have a 2001 LX coupe and my joint is tight and withing spec, but it is making a knocking noise. How difficult and involved is this job? I know I need a press to press the joint, can I have a shop do this for a small fee? Any tutorials you have used online to do this? Thanks,
Greg
Old Mar 22, 2008 | 02:55 PM
gwl's Avatar
gwl
Default RE: Replace lower ball joint
Are you sure its the ball joint, sometimes a knocking noise is a sign of a bad cv joint.
Old Mar 22, 2008 | 03:38 PM
gred001's Avatar
I took it to Skip's Auto to get the alignment done and they told me the lower ball joint was within spec and not loose, but making a knocking noise. They also told my my control arm bushings were torn. How could I tell if it was a CV joint or not?
Old Mar 22, 2008 | 10:22 PM
AgentofDarkness's Avatar
Pretty easy to tell if its your CV joint. Look on your axles, there is a rubber boot on theend. If the boot is ripped, your CV joint is probably bad.
inthezoneac
Aug 2, 2010 07:05 PM
javon
May 22, 2008 08:56 PM
SiX
May 2, 2007 12:20 AM
hollis
Apr 1, 2007 06:20 PM
anthony_delprete84
Aug 9, 2006 09:11 AM
