Replaced distributor car ran now wont start
Old Jul 6, 2013 | 02:13 PM
brandonkf4oar's Avatar
Default Replaced distributor car ran now wont start
To make a long story short. I have a 1994 Honda Civic EX The o ring was leaking so I went to replace it not knowing that the dizzy adjusted the timing. the car ran fine for a while I did put in new spark plugs car still ran fine. Same day Went to start the car and it would not start. Bought new dizzy online installed it today adjusted it to where timing seemed okay enough to get to to someone who could get it perfect for me car ran great for about 15 minutes then I out of nowhere lost power and had to pull over and be towed home. Now car trys to start but will never startup I am at a loss as to where to start now. What got me was as i got it to the point where it wouldnt start. bought new dizzy installed it it started right up. Am I frying the whole dizzy?
Old Jul 6, 2013 | 09:55 PM
Mecca8383's Avatar
You might wanna check to see if the spark plug wires are in the right places on BOTH ends...that's where I would start.
Old Jul 7, 2013 | 05:35 AM
This would be a good time to step back and go through the whole "cranks but won't start" troubleshooting drill rather than immediately assuming that the problem is the distributor.
If it is a spark problem, the coil in the distributor is prone to blow out from firing into an open circuit, such as running with a spark wire disconnected or having a bad spark wire.
roastbeefsandwich
Jun 29, 2012 12:46 PM
mattastic31632
Jul 7, 2008 04:45 PM
Red Hot Rider
Dec 31, 2007 02:51 PM
burtonripply
Oct 14, 2006 10:51 PM
