Rotors & pard
I just completed my 1st brake job on my 03 civic & I had 1 major problem. After installing the new rotor & pads it was impossible to get the caliper to fit. I did push the cylinder all the way back into the caliper & removed the shims from the new pads. It just would not fit. I checked with the store & they assured me I had the correct parts. The only way I could make it work was to use the new innerpad with an old outer pad (the old pad still had a lot letf). Same problem on both sides. Anyone else ever have this problem? The brakes seem to work fine & the pulsation from the warped rotors is gone.
I have read in other posts that people who had difficulty with getting their caliper down after the new install had the wrong thickness.
Do we have a maximum thickness? I'm sure there is. this would enable you to know if your pad is the wrong type.
Booshanky
Sep 3, 2010 03:19 AM
mchiles
Apr 26, 2005 08:22 AM
mchiles
Apr 26, 2005 08:18 AM
