HondaCivicForum.com
-   -   Rough Idling on 99 Civic CX (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/rough-idling-99-civic-cx-91272/)
ashlauren Nov 14, 2011 12:39 PM
The car only idles rough, once accelerating it's fine.
Recent replacements: tune up, thermostat, and distributor.
I'm thinking about cleaning the IACV? Any other ideas?
Check engine light is not on, and otherwise the car drives fine.
cvcrcr99 Nov 14, 2011 01:14 PM
Welcome to the forum ashlauren.
When did these symptoms begin? After or before you installed these parts?
If after wards, I would check to make sure your timing is correct. If before, I would suggest to check the spark plugs and wires (if not done in the tune up which you stated), and clean our your IACV and let us know what happens.
ashlauren Nov 15, 2011 10:37 AM
In the tune-up, the timing was checked, and all new plugs and wires.
Also, the car does not always have the rough idle, only occasionally, about once/day (I drive roughly 65 miles per day, mon-fri).
AZipper Nov 16, 2011 06:43 AM
I'm having similar problems. Once I accelerate there is no roughness. The car idles rough. I have considered replacing the distributor. I believe that it may have somethin to do with timing because it also skips sometimes when driving.. not sure. I definitely need to get a diag.
cvcrcr99 Nov 16, 2011 08:19 AM
Gave you guys cleaned out your IACV? Just wondering.
