running issues no-one seems to know
2001 civic a2 engine
I start car from cold run it to hot drive 30min no problem runs like it always had
shut it off for hour and start it it runs for a couple minutes then goes into a "limp" mode it doesn't have a miss but doesn't have power and wont hardly idle
i can shut it off and 10 to 15 minutes later it drives fine again
during that time fuel pressure is same and proper
i pulled o2 sensor out and it ran same
I cleaned egr same
changed throttle assembly which included 4 sensors idle air throttle position sensor and 2 more same running
compression all same and good
swapped all 4 coils from running car same running issues
I changed cam position sensor
I cleaned egr same
i changed computer and ignition switch it had new problems BUT i checked codes again and it told me cam position sensor
i changed it and drove it one day so far and no running issues maybe i got it thanks
i think you solved your issue. try clearing the codes and if they go away you're all set.
