Secondary o2 sensor purpose?
Old Jun 17, 2008 | 11:22 PM
JW93EX's Avatar
Default Secondary o2 sensor purpose?
Does the secondary 02 sensor do anything besides detect clean air after the cat? Does it effect the way your engine runs?
Old Jun 18, 2008 | 05:26 AM
JimBlake's Avatar
Default RE: Secondary o2 sensor purpose?
The Primary O2 sensor is the final feedback signal for fuel control.
The secondary O2 sensor shoulddo nothing to control your engine. It onlytries to verify the proper activity in the catalyst. Its not actually measuringCLEAN air...
Theres actually quite a few sensors that do nothing except verify that the smog equipment is working. Thats the big difference with OBD-2.
Old Jun 18, 2008 | 06:09 AM
JW93EX's Avatar
So basically I should not really worry about the secondary 02 sensor not being hooked up.
Old Jun 18, 2008 | 07:30 AM
FlipHKD720's Avatar
no withut the secondary sensor hooked up you wil get a CEL. If you don't want it hooked up, you'll need an o2 simulator to trick your ECU.
and yeah all it does it measure your cat's efficiency.
Old Jun 18, 2008 | 07:35 AM
ATL96LX's Avatar
or what i did when i installed my header was plugged in the secondary O2 sensor and because i need an 02 with longer wires i just tucked it behind my headlight and it reads fresh air all the time and i have no check engine light...been runnin it this way for about 6 months now with out problems
Old Jun 18, 2008 | 08:41 AM
FlipHKD720's Avatar
^ never heard of that, but if you don't have a CEL i gues you can't complain.
Shingpumps
Jan 15, 2008 01:18 PM
stylincompact
Nov 12, 2007 05:30 AM
stylincompact
Aug 10, 2006 01:51 AM
csned1
Aug 2, 2006 04:35 PM
FlipHKD720
Jul 29, 2006 10:19 AM
