si ecu vs ex ecu?
You may very well be right. I assumed that the ECUs would be different for the two different types of engine.
Also, does you Si have an automatic transmission (=code 19)? The ECU should be matched for both the engine and transmission.
RonJ, he's referring to a 92-95 Si and EX, which both have the same motor (D16Z6) and ECU (P28).
I agree with RonJ, if it is the ECU at fault for throwing the CEL, then it is probably that you are using an automatic ECU in a manual car, or vise versa.
ORIGINAL: RonJ
Trust, thanks for the clarification. So do you think code 19 is indicating a mismatch with respect to transmissions?
trustdestruction
Jan 29, 2009 12:02 PM
Civic maniac
Nov 30, 2008 01:58 AM
Captain_Sl0w
Aug 19, 2008 06:41 PM
theShamgod
Aug 15, 2008 02:48 PM
