Si wing mounted on EX
I just bought my wife a 08 Coupe EX. I tried to talk her into a Si, but she wanted a automatic. Now she wants the wing off the Si, mounted on the EX.
I know anything can be done, but I know I have to take the little wing off the trunk to mount the new wing. What problems will I run into? Will the holes line up? Will holes be exposed? Thanks in advance for any help you can give me. |
RE: Si wing mounted on EX
best thing you can probably do is take both of them off carefully, be prepared to buy some rubber or plastic o-ring type setups to seal the holes up good to prevent rust. I wouldn't reuse the old ones. If the holes don't line up, you can drill new ones and just seal them as above mentioned. Seal the old holes up with some type of silicone caulk or something that dries to a rubber constency. As long as the old holes arent going to be uncovered by the new wing and as long as they arent too close to the new holes, you should be okay. --- I've had some experience with universal spoilers before... Just my two cents here.
| All times are GMT -8. The time now is 07:05 AM. |
