smog
Old May 4, 2008 | 06:28 PM
jpnolan's Avatar
Default smog
well now that ive got the ef running i want to get it smogged before the turbo goes on or else i obviously wont be able to pass living in cali. ive never gone to get one of my cars smogged so if some one could just sum up whats going to happen what theyll check ect. keeping in mind i have a 90 with a 96 motor and a 90 ecu. thanks for the help... also o2 sensor wire got riped off will this cause me to fail? also any tricks you know of to pass smog
Old May 4, 2008 | 06:30 PM
jpnolan's Avatar
Default RE: smog
also my cel is on will this cause me to fail? im guessing its on because the o2 is pulled
Old May 4, 2008 | 09:37 PM
gsumano's Avatar
Default RE: smog
Smog place won't even test if you have cel.
Smog varies a little on the area you live, becuase of heard that some places in south cali smog you car on the dyno[&:], I'm guessing that only rich area parts.
But all cali smog test consist of a visual test (making sure there is nothing illegal) an ecu test and the sniffer test
I'm pretty sure they are going to give you crap about swapping the motor because the motor it's obdII and your ecu it's OBD0?
Old May 4, 2008 | 09:41 PM
Hailchristian's Avatar
Default RE: smog
Yeah..you might have to get your car bared unless you go to a shady place and they just dont know or you pay them off.
I had to test mine on the dino, they didn't hook anything up to my ecu. i had a visual test and a sniffer test. they checked my gas cap too.
check the internet and you should be able to find a site that will give you all the info on getting your car to pass smog since that is a very popular swap into crx's and efs
Old May 5, 2008 | 04:31 PM
sacicons's Avatar
Default RE: smog
do the conversion to obd1 and make sure all of the wiring and emissions stuff is hooked up right, then tell them its a 95 motor, or you dont really stand a chance. and yeah, unless its an illegal smog, youll have to get it Referee'd/BARed. and if you get pulle dover with an illegal motor, the cops will send you to the referee anyway, and fine you.
exhuman
Apr 18, 2005 09:55 AM
Super Mario
Dec 5, 2004 10:11 AM
Super Mario
Nov 2, 2004 04:40 AM
sacicons
Jul 10, 2004 02:09 AM
NTX
May 24, 2004 01:30 AM
