So I know this forum is for Civics but...
Old Feb 5, 2008 | 02:11 PM
isritter's Avatar
Default So I know this forum is for Civics but...
...so far I've had good luck on this forum.
Here's the deal! My wife drives a '94 Accord and I need to replace the battery cable for the + terminal. I think this is called a starter cable, is that correct?
Question I have is, how difficult is this to replace and is there anything that I need to do before connecting it (i.e. Disconnect the battery, yadda yadda)?
Please advise.
Old Feb 5, 2008 | 02:23 PM
Default RE: So I know this forum is for Civics but...
ya just simply disconect the ground wire from the battery and your good to change the power wire.
very easy!
Old Feb 5, 2008 | 02:31 PM
isritter's Avatar
Is it called the starter cable? The + cable that is?
Please excuse the ignorance. I'm a noob.
Old Feb 5, 2008 | 02:37 PM
Positive battery cable. If it's like a Civic it probably has a branch in it with a big wire going to the starter and a smaller one to the underhood fuse box. Buy one from a dealer, it'll be a lot cleaner install than the universal fit ones sold at parts stores.
Old Feb 5, 2008 | 07:21 PM
JimBlake's Avatar
Try www.hondaaccordforum.com - you might even see some familiar names...
But you've already got the right answer here. I don't know exactly how the (+) battery cable branches on a '94 but it probably has to go to the starter and to the fusebox.
Once you've disconnected the (-) battery cable, you're safe to work on the (+) cable without worrying about shorting stuff out with your wrench.
Spanky
Jul 6, 2007 08:27 AM
msa1t0t
Jul 21, 2005 07:58 PM
