Spark Plug recommendations
Old Jan 3, 2008 | 03:42 PM
MXandSXracer21's Avatar
Default Spark Plug recommendations
What spark plug does everyone recommend that's reasonably priced for a stock 01 civic LX?
Old Jan 3, 2008 | 03:52 PM
civicraider's Avatar
Default RE: Spark Plug recommendations
oem spec like a bosch but you wont need the platinum.
Old Jan 3, 2008 | 04:00 PM
bosch sucks
NGK or nothing
Old Jan 3, 2008 | 04:17 PM
Civic Si 00's Avatar
Bosh is junk [sm=violent053.gif].. I go with NGK my 1st choice and Denso is also good..NGK all the way
bro.
Your car also uses the same as mine Double platinum. That's whatcomes from OEM.I did the search for your car those plugs have the model #. Yeah they are pricey but I found this guy from e-bay who has them I made him an offer 7.00 each He said yes so I bought 8 plugs to save 4 for later. He is listing them as buy it now for 8.95. If you are interested I'll give the link to his page. Hope this helps out
Sorry I just checked with that seller and he is out of those plugs.
I found another seller but they are little more expensive.
http://cgi.ebay.com/ebaymotors/4-NGK...spagenameZWD1V
O2 SensorsSpark Plugs
Make: HONDA
Model: CIVIC - LX
Year: 2001
Engine: L4 - 1.7L - FI - D17A1
= ultimate class
= premium class
= super class
= regular class
14mm, 3/4" reach, 5/8" hex, gasket seat, resistor, ISO length, projected extended tip, V-power (v-grooved center electrode), .044"gap [/align]
Spark Plugs
Iridium IX plug, 14mm, 3/4" reach, 5/8" hex, gasket seat, resistor, ISO length, projected extended tip, fine wire (0.6mm) iridium center electrode, tapered cut ground electrode, .044"gap ', 325);" onmouseout=hidePreview(); bgColor=#c6e6ff>
NGK
IX iridium
6441
ZFR6FIX-11
.044"
SOHC
$7.32
Platinum plug, 14mm, 3/4" reach, 5/8" hex, gasket seat, resistor, ISO length, projected extended tip, extreme long life double platinum, fine point platinum on center electrode, platinum tip laser welded on ground electrode, .044"gap ', 325);" onmouseout=hidePreview(); bgColor=#b3d2ff>
NGK
Double Platinum
3271
PZFR6F-11
.044"
SOHC
(Original Equipment Manufacturer, and/or Original Equipment Service Part)
$11.71
Spark Plugs
Platinum plug, 14mm, 3/4" reach, 5/8" hex, gasket seat, resistor, ISO length, projected extended tip, long life single platinum, platinum center electrode only, trapezoid (beveled cut) ground electrode, .039"gap ', 325);" onmouseout=hidePreview(); bgColor=#c6e6ff>
NGK
GP platinum
7100
ZFR6FGP
.044"
SOHC
$2.82
Spark Plugs
reach, 5/8" hex, gasket seat, resistor, ISO length, projected extended tip, V-power (v-grooved center electrode), .044"gap ', 325);" onmouseout=hidePreview(); bgColor=#c6e6ff>
NGK
V-power spark plug
4291
ZFR6F-11
.044"
SOHC
$2.52
Old Jan 3, 2008 | 06:19 PM
Thanks for your help Civic SI!
Old Jan 3, 2008 | 07:50 PM
vmf's Avatar
vmf
im picking up platinum ones tomorrow from the local autozone store.
these are OEM plugs and should last longer then other ones
Old Jan 3, 2008 | 08:48 PM
ORIGINAL: vmf
It depends because auto-zonedidn'teven have those plugs NGK Laser Platinum Premium. Those are the plugs he needs and the ones I also use. Those plugs meet requirements for OEM. But you can go with a lower model Like Iridium or Iridium IX. I couldn't even order them at all.
Old Jan 4, 2008 | 03:40 AM
You guys all need to check your manuals before tossing in plugs. Mine (99 EX) clearly stated that I was NOT to run any platinum/iridium crap
Old Jan 4, 2008 | 05:07 AM
My04Civic's Avatar
Administrator
[sm=icon_rtfm.gif]it clearly states in your manual what plugs to use and what plugs not to use, follow it. nothing fancy...just get the oem replacements.
Old Jan 4, 2008 | 01:02 PM
ORIGINAL: My04Civic
Yeah but my car asks for the double platinums. I own a 00 SI
