HondaCivicForum.com
-   -   spark plug wires???? (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/spark-plug-wires-81418/)
frankenstein616 Mar 7, 2010 01:02 AM
i have a d17a2 in my 01 civic ex. i was wondering what plug wires to use, because the only ones that i have gotten quoted from my auto store were $60/wire. is there another alternative than going to honda themselvs and paying even more???
mk378 Mar 7, 2010 04:56 AM
Starting in 2001, Civic ignitions went to a distributorless system. The unit attached to each spark plug is not a wire, it is a complete system of module and coil. This is also known as a "coil over plug" system, not to be confused with a "coil over" suspension spring.
The coils are typically replaced only should they go bad, not pre-emptively. For a tune up replace the plugs but reuse the coils.
Dealer list on them is also about $60 each, which means you can get them for about $45 from Majestic Honda.
RonJ Mar 7, 2010 06:33 AM
Avoid taking advice from any auto parts store that tells you that your 01 Civic has standard spark plug wires.
frankenstein616 Mar 7, 2010 05:18 PM
they did tell me that they were coil wires i just thought that i could maybe upgrade them but i guess not
