Speedo Intermitant
Old Mar 15, 2006 | 09:20 AM
nedjinski's Avatar
Default Speedo Intermitant
1995 DX
my speedometer cuts in and out - is this an electronic speedometer? is it likely to be a loose connection?
Old Mar 15, 2006 | 03:46 PM
jake11375's Avatar
Default RE: Speedo Intermitant
Subscribing as I have the same problem. Speedometer and odometer. It's beginning to become very irritating. Dealer wants $80 to check it out, I've been too lazy. They said it is either bad cables or could be the sensor going out. I just may pull out my cluster tonight and take a look. I'll let you know what I find out. [sm=smiley20.gif]
Old Apr 9, 2006 | 01:28 AM
fatboyrecords's Avatar
im having the same problem with my 1996 civic dx, i have a SI cluster in it and i just replaced the speed sensor and it still didnt work. so i think i will take the cluster out and see if its some loose wires.
Old Jan 23, 2007 | 03:12 PM
98civex's Avatar
any fix for this? for i have just started experiencing this, right when the cold hit too, so makes me think its coincidence and will fix itself heh
Old Jan 23, 2007 | 03:37 PM
Fiirkan's Avatar
ORIGINAL: 98civex
thread from the dead.... just get a new cluster(if you have one without a tach then this is the prime oportunity to gt one with a tach) that is what i did. if that doesnt work then it is you'r speed sensor..... and the cluster is cheeper go with that first
Old Jan 23, 2007 | 04:02 PM
thats what it did on my 92 hatch, the speedo would work when it wanted to work soi got a ex cluster and that solved the problem
Old Jan 23, 2007 | 11:03 PM
98civex's Avatar
so if its a cluster problem it cant be fixed without replacement like a wire or something or is this a circuit thing? with a new cluster wont milege readings be wrong?
Old Jan 28, 2007 | 11:08 PM
98civex's Avatar
update the speedometer jumps to 0 and back to actual speed usually right after i shift gears, is this any help to determine weither its the sensor or speedometer itself?
bigmeat
20
Aug 21, 2010 11:13 PM
2001zrx1200r
Jun 6, 2008 06:28 AM
iamurDJ
Apr 9, 2006 05:38 PM
derekdunham
Nov 20, 2005 10:30 AM
nigel_miguel
Jul 6, 2005 09:38 PM
