HondaCivicForum.com
-   -   speedo out ...help???? (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/speedo-out-help-92711/)
honda-rookie Mar 24, 2012 06:18 PM
I have a 99-00 civic ex, when I'm driving taking it easy its fine but when I speed up and run higher rpms the sppedo jumps up then bottoms out and dosent come back on till I turn the car off any help on this ?????
mk378 Mar 24, 2012 06:32 PM
Does the odometer keep rolling normally? (even though speed needle shows zero, odometer should be moving whenever the car is moving) Does the check engine light come on?
honda-rookie Mar 24, 2012 06:47 PM
No the odometer goes out also and the check engine light is on had it checked out but it only came up for not having a cat in it (another thing I need to fix )
