speedometer
Old Jun 9, 2007 | 10:28 AM
jman's Avatar
Default speedometer
i have a 1994 civic and the speedometer does not work it is stuck at zero what do i need to replace to get it working i need it cause its a stick and im just learning how to drive one and the speedometer will let me know when to shift
Old Jun 9, 2007 | 11:46 AM
Default RE: speedometer
Does the odometer still go, counting up miles when you drive?
Is the yellow "engine check" light on the dash on? (If not, also check that someone didn't remove the bulb. This light should come on when you turn the key to on without starting the engine).
Old Jun 10, 2007 | 06:20 PM
jman's Avatar
the speedometer needles just does not move everything else works
Old Jun 10, 2007 | 06:31 PM
Then you need the speedometer itself, but it isn't designed to be field-replaced. You'll probably need to buy the entire instrument cluster (spedometer, gas gauge, temperature gauge, warning lights, etc). The cluster is easy to change out.
Old Jul 31, 2007 | 12:12 PM
crsoardREX's Avatar
Just to let u kno, NO EFFINCE- but the Tach lets u kno how many rpms the engine spins in accordiance to when u need to shift- not the speedo. try going to a junkyard for just the speedo gauge.
Old Jul 31, 2007 | 07:41 PM
Solid_Snake's Avatar
ORIGINAL: crsoardREX
Maybe his car wasnt equipped with a tach..
Old Aug 10, 2007 | 04:31 AM
yingster's Avatar
u can replace the unit within the cluster itself. u will save lots of monies. go to discounthondaparts.com and buy through them.
Super Mario
Jun 21, 2005 12:59 PM
ahhsimon
May 8, 2005 10:07 PM
billybaroo
Mar 2, 2005 11:33 PM
dayquon
Sep 1, 2004 02:45 PM
AnakinKenobe
Aug 19, 2004 05:44 AM
