HondaCivicForum.com
-   -   Speedometer help - DX 1993 (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/speedometer-help-dx-1993-a-74084/)
LorenzoMista Mar 9, 2009 09:25 PM
Hey guys. Well I'm new here and I have a problem! My speedometer isn't working correctly. Sometimes it works fine, and other times it doesn't work at all( It shows that I'm going 0 mph when I'm actually going faster ). Sometimes the needle also jumps up and down, like from 0-60 even though I'm going like 35 or something. So what shoud I do? I asked around and a lot of people told me it was my speedo cable. So I bought the only one I could get my hands on( It's kinda a crappy generic one but should work ).
If the speedo cable is the problem then how do I install it?
And if the speedo cable isn't the problem, what is?
I drive a Honda Civic DX 1993
RonJ Mar 9, 2009 09:48 PM
You don't have a speedometer cable. It's an electrical system that gets a signal from the vehicle speed sensor (VSS) located atop the transmission.
Do the odometer and tripmeter also not work? Is the CEL ON?
LorenzoMista Mar 9, 2009 09:51 PM
Everything works except for the speedometer. What is a CEL?
RonJ Mar 9, 2009 09:53 PM
CEL = check engine light
Given that the tripmeter and odometer work, the speedometer itself in the gauge assembly is likely bad.
Paul C Mar 9, 2009 10:40 PM
i had the same problem on my 92 hatch...i bought a vss off ebay for like 30 bucks and it fixed it...its on top of the transmission...can someone up the honda manual pic for this guy?
RonJ Mar 9, 2009 10:42 PM
The fact that the OP's odometer and tripmeter work proves that the VSS is fine.
Paul C Mar 10, 2009 09:25 AM
my trip meter and odometer worked most of the time when i had that problem
jprommel Mar 10, 2009 09:30 AM
most of the time or all of the time? that is key
RonJ Mar 10, 2009 09:39 AM
Your statement suggests that the trip and odo also did NOT work some of the time, which together with your speedo problem, is consistent with a faulty VSS.
This differs from the OP, whose response I interpret to mean that the trip and odo always work. If correct, then the VSS must be fine as the speedo, trip, and odo equally depend on a properly functioning VSS.
Paul C Mar 10, 2009 10:03 AM
oh okay i understand now
