no heat at idle in 2003 civic
Old 12-04-2010, 01:59 PM
hunter43221's Avatar
Default no heat at idle in 2003 civic
car only blows cold air while in idle, above 2000 rpms, heat is normal. Checked the coolant level and it is normal. Engine temp gauge is normal. Thanks in advance for any help....
Old 12-04-2010, 02:06 PM
Did you check the level in the radiator itself? It can be "normal" in the white plastic tank but actually low in the radiator and engine where it matters.
If it's not that, you may have a partly blocked heater core, flushing it out could help.
Old 12-04-2010, 02:13 PM
Thanks, I will check the radiator water level first thing tomorrow.. checked the radiator this am, even though the reservoir was full the radiator was not full. added coolant and heater ok now......Thanks, I learned something new today....
Old 12-05-2010, 12:13 PM
Keep an eye on it. The radiator cap controls the flow in and out of the reservoir, try a new one if it happens again. Ordinarily the radiator should be full to the top when you open the cap (only with the engine COLD of course).
wibevie
02-21-2023 10:08 PM
farmerj
01-26-2019 08:24 AM
wibevie
09-19-2010 04:33 PM
sylver8248
08-27-2008 05:23 PM
Devil
01-31-2005 03:16 PM
Quick Reply: no heat at idle in 2003 civic
