Steel Rim Questions
Old Feb 15, 2010 | 05:07 PM
AmexBlackG5's Avatar
Default Steel Rim Questions
Does anyone know if the YR:2000 Civic take a different OEM steel rim. I keep hearing they are different type of steel rims for the civic but all of them are the same size. I recently got a donut from the junkyard but one didn't fit and they both came of civic's just different brand help?
Old Feb 15, 2010 | 06:49 PM
Civics should all be 4 x 100 bolt pattern. Certainly the 2000 EX is one that would be. You probably don't actually have a Civic wheel, unless someone has done something weird like swap the hubs on your car to non-Civic ones.
If you measure across two opposite studs or holes it should be 100 mm (3 15/16 inch) from center to center.
Old Feb 15, 2010 | 08:14 PM
TheJGB3's Avatar
I believe ALL 1988-2005 Civics are 4 on 100MM. 2006+ Civics are 5 on 114.3MM.
MagicPinstripes
Jun 30, 2008 07:19 AM
12envy
May 23, 2008 07:45 PM
donh20001
Apr 13, 2008 05:52 AM
oldguy
Mar 17, 2007 01:03 PM
nwhite82
Oct 16, 2005 04:26 PM
