Still overheating, bad sensor????
Old Dec 27, 2011 | 07:10 PM
Loveoldhonda's Avatar
Default Still overheating, bad sensor????
I have a 2000 Honda Civic, which shows on the panel as if it was overheating, however it doesnt necessarily do it every time I drive, sometimes it does , sometimes it doesn't. the weird thing is that the needle for the temperature start raising if im sitting still for more than 2 minutes and the engine is running, however, as soon as I start moving then the needle starts going down to normal levels of temperature. I had a new radiator put in about 6 months ago, new thermostat 3 month ago, timing belt and water pump replaced, also 6 to 8 months ago, new distributor, spark plugs, and the list goes on..... I've also had the cooling system flushed out and a month after the car was doing the same thing. Could it be a bad sensor??? or what else? I dont know what else to do with this car, I have taken it to 3 different mechanics and no one seems to know why it does this or how to fix it!
Old Dec 27, 2011 | 08:12 PM
90 Civic's Avatar
My guess is there is air in the cooling system which will cause the condition you described. Bleed the system. I had the same with our 90 Civic. It was fine then I found myself 300 miles from home in downtown Las Vegas in August. It started overheating. I got it to a friend of mine's place & we bleed the system which take some time to do it as Honda says & never have had another issue.
Old Dec 28, 2011 | 07:18 AM
Scout1's Avatar
I am new to the Honda world but check your electric fan. I believe if you turn your A/C on your fan should run.
Ed
CID Vicious
Dec 11, 2008 06:13 PM
vtec02
May 9, 2007 05:17 AM
batac_boy
Mar 4, 2007 04:51 PM
trebor_2005
May 19, 2006 01:40 AM
