| Loveoldhonda |
Dec 27, 2011 07:10 PM |
Still overheating, bad sensor????
I have a 2000 Honda Civic, which shows on the panel as if it was overheating, however it doesnt necessarily do it every time I drive, sometimes it does , sometimes it doesn't. the weird thing is that the needle for the temperature start raising if im sitting still for more than 2 minutes and the engine is running, however, as soon as I start moving then the needle starts going down to normal levels of temperature. I had a new radiator put in about 6 months ago, new thermostat 3 month ago, timing belt and water pump replaced, also 6 to 8 months ago, new distributor, spark plugs, and the list goes on..... I've also had the cooling system flushed out and a month after the car was doing the same thing. Could it be a bad sensor??? or what else? I dont know what else to do with this car, I have taken it to 3 different mechanics and no one seems to know why it does this or how to fix it!
