HondaCivicForum.com
-   -   Stranded 98 civic ex 5-spd cel code p0108 (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/stranded-98-civic-ex-5-spd-cel-code-p0108-87429/)
illlili Jan 28, 2011 03:32 PM
Thank you all for visiting.. I'm on thin ice with my absence from work due to my civic's sudden death..
Less than a week ago I left to work and upon starting my car it first started normal, then seconds later it backfired for the first time while the rpms shot up around 1500; then fluctuating up and down between 1500 and about 900 evey 10 seconds or so...
I thought i would just tough it out and drive to work but as soon as I went to drive the car bogged and wanted to stall..
So far I have replaced the plugs and wires and thoroughly cleaned both the TB and the IACV..
I also sprayed the vac lines with TB cleaner to test for leaks..
Coolant was low and topped off..
Problem remains.. Undriveable..
PLEASE HELP!
mk378 Jan 29, 2011 07:26 AM
Timing belt may have skipped. Check the cam timing. Backfiring usually means something is way out of time.
