HondaCivicForum.com
-   -   tail light not working? (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/tail-light-not-working-32735/)
89redcivic Nov 15, 2006 10:31 PM
when step on the brake the light doesn't light up? night light work, signal light work. only brake. checked wire, all fuse not blown. what else can cause this? any help will be thank.
Misha Nov 15, 2006 10:38 PM
RE: tail light not working?
Did you check the switch itself? And the bulbs, btw.
luisynayan Nov 16, 2006 07:05 AM
+1 on checking the bulbs. I suggest checking the wiring again. I had the exact same problem in the past, ends up there was a cut wire that needed splicing and reconnecting...
89redcivic Nov 16, 2006 05:56 PM
bolbs are good, wire tested, no positive coming. negitive work?
Misha Nov 16, 2006 06:09 PM
Not sure what you meant by "negative work". Did you check the switch itself?
89redcivic Nov 18, 2006 11:32 PM
what switch?
Misha Nov 18, 2006 11:46 PM
Brake light switch. located at the brake pedal, up under the dash;)
