Is there a fuse for the distributor?
Does any body know if there is a fuse for the distributor? if yes where can it be found? the car is a 95 ex 1.6L. Thank you.
what is your problem,battery going dead
There's no spark. I was gonna replace the distributor but first I want to know if there is a fuse for it that I can check.
i was thinking alt,had a brain fart
it is possible that its dead,check all wires leading from dist for power |
The black and yellow wire powers the distributor. It comes from a fuse under the dash.
Before replacing distributor because of no spark, also check that: ECU powers up (CEL cycles on and off) camshaft rotates (if timing belt stripped, there will be no spark) |
