Tie bars install Q's
Where exaclty to the front and rear tie bars go. The only place in the front that the tie bars line up to any bolts are the lower control arm mounts. Now the rear... I have a sway bar on there. Is that causing clearance problems, becuase (as simple as it is) I'm having problems installing the rear one. The front one looke like a miniature upper strut right. And the bolt for it goes from front to back, while the bar "hangs" left to right. And the rear goes on the lower trailing arm mounts on what you could say is the "cross member" (I know it's not). Any Help? I probably sound like a total moron asking about this stuff:eek:)
RE: Tie bars install Q's
Bump! C'mon guys I know you have an answer for me, Sac, Remmy, LEVIII, Kappa, Forty, Negoti8tor, Where are you guys!!!!
I know someone has an answer... I beckon upon those of vast knowledge pertaining to the area of the all mighty HONDA CIVIC! |
Yo, wheres my t-shirt dawg?!? :D
Clicky Clicky ^thats my install page, check out near the top. I'm not sure if thats what you're looking for or not, but it might help |
some jack ass in my print shop deciede to wash off my screens and make them blank ones.[sm=badbadbad.gif]
So I'm in the process of setting them all up.... again. you wanted just one right? I'll get those for ya as soon as possible!!!! I'll even make up for the wait... |
oh yeah, those pice were just what i needed! Thanks forty
No problem, and no problem, I was just giving you ****:D
And yeah, I just needed the one Medium Black |
i didn't have a problem installing my rear lower tie bar at all, but i don't have a sway bar either.
I think that having the sway bar on there is what is giving me a hard time. If i can't put on the rear tie bar then that is ok, because I have a sway bar which is way better than a tie bar in my opinion. Oh well, I'll just put the front lower on and leave it at that. By the way, For those of you contemplating getting strut bars to improve handling. I would say that they are absolutely worth it. I would say they reduced body roll in my car by 70%!!!. It was absolutley worth it!
