HondaCivicForum.com
-   -   TIME FOR A TUNE-UP (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/time-tune-up-16752/)
95CIVICUS Feb 9, 2006 10:56 AM
TIME FOR A TUNE-UP
Ok so what are the best plugs one can use. i already have to buy alot of expensive things to do this so i am going to go all out onit. i have to buy a MSD Distributor cap and rotor button, Blaster 2 coil w/ extrra wire, and MSD 8.5mm wireS.
SO i need to know, WHAT ARE THE BEST PLUGS ONE CAN USE?
i currently have NGK iridiums.
I have a 95 D16y8.
so tell me what do you use?
what do you like?
and what do you reccomend?
does MSD make plugs?
usmc2b2004 Feb 9, 2006 11:04 AM
RE: TIME FOR A TUNE-UP
I use NGK iridiums thats just me though I never had any probs with NGK but Im not sure if msd makes plugs
ef4life Feb 9, 2006 02:11 PM
ngk's are the oem honda plug, and the iridiums work great
Pete Feb 10, 2006 01:40 AM
yes, use NGK on honda, THats it. I own a turbod honda and guess what plugs i use?.............N G K
my_hidden_romance Feb 10, 2006 01:51 AM
funny u all say ngk i use bosch platinum 2s.. ive never had a problem before in my life.. then again im driving a daily driver...well.. was.. but all my vechiles have them.. even my minivans.. they are the best daily driver/performance plugs i have found... and the best part i like...no gapping!!!
larsenracing Feb 10, 2006 08:10 AM
I'm all about NGK. I stay away from platinum yes they are ok for a n/a daily driver but they burn hotter. I would go with NGK because they are the stock plug and they work fine they may not work as long as a platinum but com on plugs are cheep also gaping your plugs is easy only takes about 20 seconds each.
my_hidden_romance Feb 10, 2006 09:34 AM
yea i know gappin is easy.. i carry a gapper with me on my key ring.. i guess that i just like the bit of better performance they put out being platinums
even though u say common plugs are cheap.. ur only replacing them every what.. 5k miles?... think of all that money thats going in to buying maybe 2 sets of ngks by then... i dunno... i just like bosch... theres a civic hatchy around here that has a bigggg ngk sticker on his car.. i soo wanna go ask him if he had to buy it extra from the spark plug set
killerformula Feb 12, 2006 02:43 AM
What upgrades do you have? Unless you have some reason for needing a better spark (big cam, rich on top end or turbo added) you don't need to spend 85 dollars for your wires and 4 dollars for each spark plug. They will give you about .2 horsepower.
K
95CIVICUS Feb 12, 2006 04:00 AM
ORIGINAL: killerformula
K
well i already have all of the MSD ignition stuff on there. it came with the car when i bought it. I have a MSD blaster 2 external coil. MSD 8.5m wires NGK iridium, MSD rotor, MSD cap. so im just going to replace what is already on there. that **** is expensive.
i did a tune up on my old car. it costed a total of 50 bucks for it. For me to replace everything with what s already on there. it will cost nearly 200 dollars.
